8 | |
3 | |
3 | |
2 | |
2 |
Whenever you use multiple scales in a graph and use autoscale the grids usually don't match. See left graph.
One simple solution is to show only one grid, however the ticks on the other scale(s) wouldn't match the grid. 😞
Wouldn't it be nice to have a autoscale with matched grids in multi axiy plots? At least as an option?
Nice autoscaling is tricky 😉 and marking the ticks is tricky (scale size/font size/...), so my simple approach only works with larger scales (and only uses the major grid) ...
