Match regular expression will return sub matches for any groups in your expression. So this expression: (\w+)_(\w+) would be sub match 1 and 2.
However, LabVIEW only returns the string of the sub match, not its offset and length. This makes doing replacements on sub matches difficult and technically impossible because you then have to do a search and replace on the sub match and hope there isn't an identical string somewhere in the full string (causing an incorrect replace).
Other languages deal with this easily by addressing sub matches by slash codes. For example the first sub match is \1 and the second is \2. So you can say... search for this and replace \1 with that.
So I propose:
