6 | |
6 | |
3 | |
2 | |
2 |
Just found out MathScript Module does not have a 64-bit version yet. I don't know if NI has any timetable to release its 64bit version?
Why do I need a 64bit version? Mainly the memory issue. I have a Matlab code which requires a massive memory allocation. Now I am trying to use the .m code in LabVIEW, but encountered a 'Not Enough Memory' warning message. I think a 64bit version shuold fix this issue, correct?
Besides, 64bit is the future anyway. So in case MathScript Module 64 bit is not even being considered by NI, I would like to suggest it here.
Available with LabVIEW 2016 and later. The MathScript RT Module has installers available for the following products:
LabVIEW for Windows 32-bit and 64-bit
LabVIEW for Mac OS X 64-bit
LabVIEW for Linux 32-bit and 64-bit
