8 | |
6 | |
4 | |
3 | |
2 |
Whilst calling a mathscript plot window and using the ginput function, behaviour is not as expected and does not behave the same as the equivalent Matlab function.
The attached example should allow me to click on the plot ten times with the output being the corresponding x,y co-ordinates of each mouse click. The issue I am having is that if the mouse is dragged any amount across the plot window, Labview/Mathscript is interpreting this as multiple inputs. Can the functionality be changed to count each mouse click on (on press or release) as a ginput event as expected?
