It would be nice if we could see the memory occupance in the run time either for the selected region of the block diagram or with the the probes itself.
The form factor of the memory monitor can be different as seperate tab in probe etc. I majorly two advantage here
1. Easy for debugging the memory issues in the suspected regions.
2. Good for beginners to consider the memory handling while they learn.
