10 | |
3 | |
2 | |
2 | |
2 |
This is an offshoot from this thread in the forum: http://forums.ni.com/t5/LabVIEW/Difference-between-Shared-Variable-Refnum-and-Control/m-p/2378020
The Shared Variable Refnum and Shared Variable Control (for the DSC Module) is essentially the same concept and I think that merging the two should be considered. The recommendation from Daniel REDS in the NI Forum thread was that I post an idea to make a silver control of the Shared Variable Refnum. I would say that would be nice, but I think that the two controls being merged into one would be more ideal since they both contain essentially the same Variable browser and conceptually are referring to the same thing.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
