| User | Kudos |
| 11 | |
| 10 | |
| 9 | |
| 5 | |
| 4 |
In a Mixed Signal Graph there isn't a documented way to programmatically change the 'Group' names.
They can be easily changed inside the editor, but not at run-time.
This request has been already discussed several years ago (see here)
