Dragging the splitter that is between multiple plot areas of a Mixed Signal Graph causes the absolute size of the plot areas to change and scroll off the overall plot. I propose that the splitter only change the relative proportions or ratio of the plot areas.
http://forums.ni.com/ni/board/message?board.id=170&message.id=386349#M386349
