When creating a LabVIEW installer, in the Source File Settings dialog, I might change the attributes of several files in the same way. For example, I might make many files read-only and/or hidden. Currently, I have to click on each file and change its attributes. I would like to be able to choose multiple files (either by highlight, control-click, etc.) and change their attributes at the same time to the same setting.
