For structures, it is possible to allow auto resizing.
This resizing only works for enlarge the struc.
It would set up a practice of providing added space between struc.
It would provide a more readable diagram and see all cable.
In the same idea, a option to shrink struc to diagram (automatic or on order) will be useful. When you make some sub vi from code, you can have a lot of space on a diagram and it's not easy to read the code.
Shrink the code with a space to add between the struc.
Ex 1 : raw code with only auto resizing.
Ex 2 : A code with space
Ex 3 : When we make sub vi, a lot of space is generated.
