The "right-click...replace" option has few choices, typically the home palette of the current selection if available and "All Palettes".
Quite often, I need the entry "Select a VI...", all down at the bottom after selecting "All Palettes".
Suggestion 1: Add "Select a VI..." to the first menu, see image.
Especially when benchmarking or trying different algoritms, I often like to replace the current VI with another VI that is already in memory.
Suggestion 2: Also add a "VIs in memory", which would allow picking from list of all VIs in memory (except things located in VI.lib or in the standard palettes).
Here's an image how it could look like:
