Dear All,
Currently to use LabVIEW in a functional way you have to spend about $5000 to get the bells and whistles.
Large corporations don't have a problem, but there is a lot of normal people that would like to have LabVIEW but are not students and can't justify spending that amount on software that they may use only occasionally, but would like to have.
Adobe has moved away from the (legacy) model where you buy and own your copy of the software, to a subscription based model ($20 to $50 a month) where you get ALL the LATEST version of EVERY application they make, as long as you pay your monthly bill. I was reluctant to use that model but I finally subcribed, and let me tell you it saves me a ton of cash, and I get whatever I need at the latest version.
National Instruments high-level management and marketing department should seriously consider moving forward and making an AFFORDABLE monthly subscription scheme, like Adobe succesfully did. This would benefit NI by getting some money out of folks like me, and would ensure that the whole world would be using the latest versions of it's products.
Successful companies are the ones that make available the best products and services to the BROADEST range of people (e.g. Google, Microsoft, Adobe). Restricting access to technology based on income will hurt National Instruments in the long run.
With best regards,
Rollin McCarty
