6 | |
5 | |
2 | |
2 | |
2 |
The LabVIEW compiler currently appears to use one core of a multi-core processor. It would be nice if it fully utilized multiple cores to speed building of large projects.
Available in LabVIEW NXG, where the compilation of VIs proceeds in parallel.
