| User | Kudos |
| 8 | |
| 7 | |
| 4 | |
| 4 | |
| 4 |
My request is for NI to review and develop the ability to select where (IP specifically) a NSV will deploy on a system (eg. PC) containing multiple networks.
After searching through various forums and issues, I understand that currently we can only choose LabView software's global default adapter via unusual Windows methods. What if other projects do need to use the primary NIC ? or what if in one project I need some NSV to go to primary NIC and some to use the secondary NIC ? As various hacks and workarounds did not fulfill my requirements I opened a request for technical support. After review, the case (#03609821) concluded that this was not possible and suggested I post here to see if others also would find this useful to boost development priority.
My example scenario is this. My company develops specialized motion products (mainly automotive transmissions for heavy duty and defense applications). We primarily use NI in our dyno and own a few NI hardware systems: cRIO, cDAQ, PXI.
I work in the dyno room here and am trying to set up a cRIO as a datalogger and RT OS to primarily measure analog and CANbus signals and thereby control testing.
The test fixture is operated on a PC with two network cards. One private LAN to talk to the cRIO to stream data and control. The network shared variables keep track of various statuses. The other network card is on the company LAN primarily so we can transfer data and share fixture status. The secondary purpose of being on the company LAN is that we have 6 configurable dyno motors (usually used in pairs) in the room that run on a shared master controller (non-NI). Currently that is done via PC RS232 to the cRIO, but we’re planning eventually to transition that to a more open ethernet architecture. NSVs would be ideal for sharing each dynos’ status as the serial is limited in 1-1 connection and bandwidth.
