The Tree- Control and the Multicolumn Listbox support the presentation of a Symbols per row. But there are a lot of cases where there is needed more than one symbol per row. One very common scenario is the display of various states (Calculation completed: Checkmark; Results written to file: Checkmark; Assigned Application to open file: App-Icon...). NI does this already in the "Example Finder" window, so it is obvious there is a need for this feature.
I think it is a good practice to hold a pool of symbols, attached to the control, like NI does currently with the Trees and MCLBs. And for performance reasons there could still be the possibility to determine the columns to be capable to display symbols.
So from the LabVIEW programmers point of view there could be added the following properties / methods:
This should provide compatibility to the current handling of symbols since the property "Symbol-Displayable Colums" defaults to [0], so if "Item Symbols" is read or written to, it is meant to use the first column, which is status quo.
