whenever a change of .NET dll is introduced, LabVIEW kept wanting to use the old dll. The change in a 3rd Party dll caused a full blown LV crash...
A simple Uninstall of the entry in C:\Windows\assembly did the trick.
This was not mentioned in the following:
https://decibel.ni.com/content/docs/DOC-5921
http://zone.ni.com/reference/en-XX/help/371361J-01/lvdialog/assemblies_in_memory/ (only talks about runtime, which is helpful when creating the distribution)
This is not obvious nor an easy to find solution. An ability to pick and choose within LV the required dll (and version) would be helpful.
