2 | |
2 | |
2 | |
2 | |
1 |
Add ability to install and update NI packages via the winget utility. This would make it easier to standup new development or test systems.
Winget has a very user friendly export/import systems that can be used to replicate development installs across multiple computers.
I think you should be able to build this around the current NI package manager system with some helper scripts.
