For all of us not running an english OS but want to install plain english versions of NI products:
Please give us an option or a documented method to install LabVIEW and MAX and driver, etc. in plain english.
While it is possible to install LabVIEW in ENG, the MAX and the driver installer lookup the OS language and install the localized versions 😞 (just tried with a new PC, W10 and LV2018 full dev suite, even set my language setting to ENG, however I have to install the localized W10) That is not helpfull if you want to look up the big commuinty help or knowledge base entries and can result in 'funny' error messages.
For the driver DVD I think I found a hack in the setup.ini
[Localization] Languages=9,7,12,17,18,2052 #ForceLanguage = 9 CustomRes0009=SupportFiles\resourceEng.dll CustomRes0007=SupportFiles\resourceDeu.dll CustomRes0012=SupportFiles\resourceFra.dll CustomRes0017=SupportFiles\resourceJpn.dll CustomRes0018=SupportFiles\resourceKor.dll CustomRes2052=SupportFiles\resourceChs.dll StandardRes0007=SupportFiles\niresdeu.dll
by uncommenting the red part. But editing the setup.ini ??
OK, in this case the hint was there (or forgotten to remove :D)
The actual suite installer comes with a .xml configuration file where that hint was missing or overseen.
I suggest something like:
Installer found local language version: <OsLang> ,
Install (where possible) in language: <ListOfSupportedLanguages>
That setting is hopefully stored for future automatic updates 😉
