6 | |
2 | |
2 | |
1 | |
1 |
For ethernet and GPIB communication I have the choice between the LabVIEW "native" drivers (residing in function palettes "Instrument I/O" and "Data Communication") and VISA. LabVIEW 6.1 was the latest version which also supports "native" drivers for serial interface. In LabVIEW 7.0 and later you are forced to use VISA.
Besides all advantages of VISA - the biggest disadvantage of it is its HUGE communication overhead it produces. If you use interface sniffer like PortMon, you will see that VISA heavily communicates with the interface chip (requesting its status etc.). So for sending a simple "Hello" over RS232 you don't have only four actions (configure port, open port, sending "Hello", close port), but ten and more.
As consequence VISA often lockes out if you have heavy traffic on your serial interface (e.g. if you have to send data every 250ms over the interface) - and if VISA lockes out, you have a serious problem...
So PLEASE, give us the native driver for serial interfaces back!
