6 | |
2 | |
2 | |
1 | |
1 |
I would like to have the possibility to "negate" some comparison functions such as "Empty String/Path?". This can avoid to add the "Not" operator.
The picture below is a possible implementation. The dot on the input (on the output ok also) is showing the negation.
This might be good to be implemented for the following functions:
Duplicate of https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Invert-Option-in-all-Boolean-Terminals/idi-p/1281058
