2 | |
2 | |
2 | |
2 | |
1 |
My idea is as simple as the title states - an additional Compound Arithmetic function that works like "Equal?", but with multiple inputs and single boolean output.
I believe it is fairly easy to implement such functionality, and I can see no other single block that could compare multiple values, and offer easy expansion as well.
The easiest way to build similarly working VI (that comes to my mind right now) below.
