13 | |
7 | |
4 | |
2 | |
2 |
When installing a new version of LabVIEW, I always find myself resetting all of the options I previously changed from the default settings in the Tools -> Options menu. This means I have to spend my time remembering what options I changed and where in the Options menu I need to change them. It would be nice if a newer installation of LabVIEW looked at the older version's Options settings and then applied those settings to the new installation.
The same idea applies to how I configure the palettes on the block diagram. It would be nice if newer installations looked at how I configure my palettes and then set them up the same way.
With these changes transitioning to a newer version of LabVIEW might be even more seamless for users that change their settings from the default settings.
