13 | |
11 | |
3 | |
3 | |
3 |
LabVIEW uses 5 types of operation behavior for push buttons. However, I have come accross a rather annoying obstacle, whenever I need to execute an event for once (turning on a simple LED AND keeping lit AND keeping the button released, for instance), I need to run through Loops or structures which consumes the space of the block diagram. Although this may sound very simple, after all I am a newbie when it comes to LabVIEW, it really helps in certain places, namely in my very simple project. Here are two of the ways that demonstrate what I am doing at the moment:
And here is how the new pressonce/execute once and for all/release block diagram looks like (excuse my English, I believe the digrams must illustrate what I want to say)
As I have said, maybe it doesn't make a difference to you, but it does to others and I am one of them, well you can either go with a while loop or without, let's keep it to the big guys to decide (this is if my suggestion gets accepted). And I am choosing a random label 😄
Thank you for your time.
