13 | |
11 | |
3 | |
3 | |
2 |
I would like to see new Read and Write VIs for TCP and UDP connections that worked the same way the Read From Binary File and Write To Binary File work. These file VIs are polymorphic and allow you to specify the format of the data being written or read. With only the current Read and Write VIs available for the TCP and UDP connections we must always include typecasts or other data parsing. LabVIEW obviously has the means to do this since it exists for files. Extend that capability to the newtrok connections as well.
