jahannah
New VI Creates Block Diagram at Origin
Status: Declined
New VI always creates with the Front Panel at the origin, but not the block diagram.  Since I use the grid on the block diagram to improve code quality, I have to manually set the BD to the origin for each New VI.  The BD should be at the origin as well as the FP.
4 Comments
AristosQueue (NI)
NI Employee (retired)
I understand using the grid for layout, but I am curious what are you doing that you care where the origin is located?
crossrulz
Knight of NI
AQ - some people are just OCD like that
Sumedha
you can use this quick drop plugin to reset the origin for the front panel and the block diagram- https://decibel.ni.com/content/docs/DOC-20833
Hope that helps!
Sumedha Ganjoo | LabVIEW R&D
Darren
Proven Zealot
Status changed to: Declined
