13 | |
11 | |
3 | |
3 | |
2 |
It is fairly common to build applications in LabVIEW that are useful to run as a service (monitoring software e.g.) , however to do so today you need to "cheat" and use srvany, and write and run batch files to get it installed.
It would be great if we could build real services, and the installer would take care of the installation process. You could even have a nice template for services with an accompanying user interface client, with notification icon and everything.
LabVIEW everywhere...Not just on different targets, but in every part of the system. 🙂
