There are already several Ideas on the exchange regarding custom error-code files. A subset are listed below:
Project error code files (request to locate error file near lvproj file, or via Project properties)
Error txt file (allow specifying a path when calling General/Simple Error Handler, store the custom file somewhere not in <National Instruments>/{Shared,<lv-version>}/...)
Make custom error code files part of a project (allow project-level error codes, not stored in user.lib)
Error ring without file (request for an error-ring typedef that could be stored in the project's source code collection)
My suggestion here is most like the last - I'd like to suggest a file type like a .ctl (or perhaps via typedef, if technically better/more implementable) that can be added to a project, library or class and contains a list of errors.
Ideally, these errors should be only possible to throw from inside the library, but must of course be visible from outside of the library.
Implementing these at the project level restricts the possibility of use with PPLs, reusable libraries, etc, because the project file is a dev-only construct (as far as I understand), unlike classes and libraries (which are part of what you distribute in whatever form you choose).
The ability to store these files in a library or class also allows the possibility of scoping the error code, such that the handler can more easily identify the source of the error.
LabVIEW already categorizes it's errors into broad sections (LabVIEW, MAX, NI Platform Services) etc and so perhaps these could be used as the scope of the existing, built-in error codes, although I'm not sure if this would require significant work or not... I suspect many things seem easier when you're not the person who will implement the changes!
