7 | |
2 | |
1 | |
1 | |
1 |
Currently the quickest way to open a typedef is right-click >> Open Type Def.
Holding down a modifier key (Ctrl, Alt, Shift, or a combination of these) while double-clicking on an existing typedef constant or terminal (Block Diagram) or control/indicator (Front Panel) would be quicker.
Notes
