 ClaudioH
			 on
		03-13-2011
		07:48 PM
			1 Comment (1 New)
			ClaudioH
			 on
		03-13-2011
		07:48 PM
			1 Comment (1 New)
Reading your sample code in http://decibel.ni.com/content/docs/DOC-12287 I had the idea that we would be able to inform Read from spreadsheet that the file has row headers and / or column headers.
When setting this, a table indicator should be created as defined by the file instead manually:
- remove the first row and set it as table column header
- make column header visible,
- remove the first column and set it as table row header,
- make row header visible.
Cheers.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
