wolfkil
Nonlinear Curve Fit.VI with error input and output
Status: Declined
Up to LV 2010 the "Nonlinear Curve Fit.VI" has an Input for the data weighting. For sure this could somehow be related to measurement errors of the data, but as this is not documented and not for a daily user well known it would be nice to have an additional instance were the input is not the "Weight" but the "Std. Dev. of y".
In a similar way it is not totally straight forward to calculate the standard deviation for the "best fit coefficients" from the "covariance matrix". So an additional output "Std. Dev. of best fit coefficients" would be very helpful.
4 Comments
altenbach
Knight of NI
I usually put a wrapper VI around it where I process the inputs and outputs further and create the data structures I need. I would hate it if we had more connectors.
wolfkil
That is easy for guys like you who knows this VI very well, but probable not for a daily user. And with the input I am asking for another instance such that there would not be an additional connecter for this. And for the output of the SD of fitting parameters I want to say that normally analysis programs (e.g. Origing, QtiPlot, PAW) give the standard deviation for the fitting parameters. So quite a lot will be used to handle with these values but not with the covariance matrix.
Darren
Proven Zealot
Status changed to: Declined
X.
Trusted Enthusiast
Trusted Enthusiast
This is a dead thread, I know, but regarding the last part of the request, the Nonlinear Curve Fit Intervals.vi (advanced curve fitting palette) provides almost exactly what the OP was asking for:
