6 | |
2 | |
2 | |
1 | |
1 |
I need "something" that is flexible and not necessarily defined during development... can be expanded or superseded over versions without breaking VIs.
currently using map, with main VI setting the keys and values and called VIs/subVIs processes only the keys specified (with default values) within the called VI itself. additional checks are required to prevent illogical or erroneous conversions during execution
something simpler/more elegant would be nice... the current ones are too "predefined" or "required to be defined'
any ideas?
