| User | Kudos |
| 12 | |
| 12 | |
| 9 | |
| 8 | |
| 4 |
The LabVIEW String/Number Conversion Palette contains many functions to convert a number to a Decimal, Hex, Octal, Fractional, Exponential and Engineering Strings. However there is one missing: The Number to Boolean/Binary String. This can be replicated very easily with the following code, but should be a native function of LabVIEW.
