3 | |
3 | |
2 | |
2 | |
1 |
We were thrilled to see that NI developed an OPC UA API. We develop software for both VxWorks and Windows, so having OPC UA available on RT is great. But having to shell out for the entire DSC suite, run-time licenses and all, just to be able to use the same API on Windows is unreasonably costly and forces us to use a different API on Windows. If we could buy the API as an isolated component at a more reasonable price (and with easier licensing) we would jump for it immediately.
A generalized version of the idea:
The DSC can still function as a nice bundle, where the price for the bundle is lower than the total for each individual item, but when NI makes such packages please make it possible to pick-and choose amongst those components as well, so that in cases where you actually have a need for just one of them, you can get it at a price that is reasonable for that individual component.
The OPC UA API is now available as a separate toolkit.
