I do a fair amount of Pipelining and it would be cool if I could Offset the Input Shift Register from the Output Shift Register.
The default would be to keep them aligned but a right - click would give me the option to offset the input or output Terminal. I think it would be bad form to allow crossing the terminals between multiple Shift Registers so the top Input terminal would correspond to the top Output terminal.
