At the moment a properies node can be linked to one object, e.g String, Boolean etc.
to change the properties of that object.But sometimes it would be usefull to have a
new type of properties node (a second beside to the existing one) whre the logic
has inversed.
NOW: 1. Propertie Node -> link to ONE object -> select from a lot of properites
PROPOSED: 1. Propertie Node B, -> select ONE properties -> link to more than one object
