Mihály
Open Class in Runtime
Status: Declined
Documentation bug
There is a managed way to open a library both in development and in runtime environment via Library.Open method. The same method is available for Class Libraries but without the possibility to open the Class in runtime environment although the Class Library is a specialization of the Library.
Therefore the getting the hierarchy and/or the members of a Class could be performed by terrifying non-managed way in Runtime environment.
It would be nice to get the same functionality from this method as found by the Libraries.
2 Comments
Christina_R
Active Participant
This is a documentation error (for which we've filed Bug 3308279). The method does work in the run-time engine.
Christina Rogers
Christina_R
Active Participant
Status changed to: Declined
Documentation bug
Christina Rogers
