When working with multiple projects at a time I try to keep all of one projects windows on my primary display and all of the windows for the other project on a secondary display. This can become tedious to move every window I open. I know each VI remembers its' last location and opens there but it would be great if there was an override setting.
So for instance, when I open a project, there could be an option in the Project menu for "Open project windows on this display" that would then force any windows related to that project to stay on the same display.
Randy B
EDIT: An alternative which might be easier to implement would be to add an option (Gather Project Windows on This Display) in the Window menu that would move all of the Projects currently open windows to the active display.
