SteenSchmidt
Open VI reference without refees
Status: New
I suggest an option added to the Open VI Reference primitive to open that VI reference without any refees. I suggest option bit 10, i.e. option 0x200h:
The demand for this arises when you want to access methods and properties of VIs that may be broken, while on the other hand you don't have any need to run those VIs - for instance in one of my current tools (BatchEditor) where I'm tasked with investigating hundreds of VIs simultaneously of which some could be broken or missing dependencies. Other situations would be tools for traversing project trees for instance. Opening a large number of healthy VI references takes a while, and when something is broken in a VI, opening even a single reference could take 30 seconds to minutes.
Currently you can suppress the "loading" and "searching" dialogs by setting option 0x20h on the Open VI Reference primitive, but that only loads the refnum silently as far as that will get you. Opening the refnum takes the same amount of time as if you could see those dialogs, and you are rewarded with an explorer window if a dependency search fails. I just want a way to open a VI refnum without even starting to look for dependencies, thus very quickly and guaranteed silently.
The relevant people would know that this request isn't that hard to implement, as it is kind of already possibly using some ninja tricks. I'd like such an option to be public.
Cheers,
Steen
CLA, CTA, CLED & LabVIEW Champion
23 Comments
Jim_Kring
Trusted Enthusiast
Wow, has it been 7 years?
There's a private Application method called "Open.VI Without Refees" that basically does this.
I've tried to use it and it seems to work well, however, it seems to end up breaking links to Express VI instances (and might also have similar problems with Malleable VIs, but I haven't tried it yet). Here's a screenshot of a broken VI that can no longer find its express VI instance.
BertMcMahan
Trusted Enthusiast
I ran into a need for this today, so kudos 12 years in 🙂
The "Open.VI Without Refees" wouldn't work with "Traverse for GObjects", I just get a "Traversal failed" error.
Obviously this is a private method so no official help, but it sure would be nice to have for my situation. Any thoughts on why it won't allow me to traverse the VI?
I'm scanning a bazillion VI's front panel and block diagrams to compile data on a codebase. I don't want to load all of their references, and I certainly don't care if those references can't be found. Setting the 0x20 option doesn't suppress the popup to try to find missing subVI's.
dadreamer
Active Participant
I use Open.VI Without Refees for traversal purposes too and the scripting works well for me. I just handle the most obvious errors, occurring when dealing with the VIs:
- 1040 - VI is locked / password-protected;
- 1012 - cannot load the block diagram / no block diagram.
Also make sure that you specified the traverse class name properly (e.g., "Invoke" for Invoke Nodes, "Property" for Property Nodes, "SubVI" for SubVI's etc.). Instead of the Traverse for GObjects VI you could possibly use Block Diagram property followed by All Objects / Nodes property.
