2 | |
2 | |
2 | |
2 | |
1 |
I tend to use malleable VIs more often than half of the items in the "New" context menu list when you right-click within a project, however, it's not an option:
Instead, I either need to:
- Create a new VI and then make several property modifications, and save it as a ".vim".
- Create it through the file menu and then remember that I need to move it to the appropriate place in my project, because it gets created at the top-level.
Why not include this in the context menu? (Bonus points if Polymorphic VIs get added too!)
