6 | |
6 | |
3 | |
2 | |
2 |
The ability to view a cluster constant as icons on the blockdiagram (implemented after an idea posted here) is great! I use this for 99% of my cluster constants. But I have to first place/create the constant, then right click it and select "View As Icon". This is a bit tedious, espescially since greating a constant for a large cluster inside a structure will often mess with your layout via autogrow. I would like to have a checkbox in the LabVIEW options that controls the default behavior so I can make "View as Icon" the default. Just like the "Place Front Panel terminals as Icons" option.
Best Regards
David
