11 | |
8 | |
3 | |
3 | |
2 |
When setting the inheritance of a class, you're only able to select classes that are currently loaded into memory:
If you're not working within a project (which I do commonly to keep things zippy), chances are the class you're looking for isn't loaded. It'd be great if there was a browse button on this UI.
(The workaround is to open the class you want to inherit, but that class can't be opened simultaneously because of the modality of this UI and that it'd need to refresh, so you need to close out of this window and the class properties window and then reopen both.)
NI will not be implementing this idea.
