SivaShankar
Option to choose Connector pane for VI from static dispatch template
Status: Declined
From LabVIEW Class, If I right click and select "VI from Static Dispatch Template" and "VI from Dynamic Dispatch Template", It always have same connector pane template 4x2x2x4. whereas I have option to change the connector pane of the "New VI" by using the LabVIEW ini.
Have an option to change the connector pane for static and dynamic dispatch template.
2 Comments
crossrulz
Knight of NI
You can try to alter <LabVIEW>\resource\Framework\Providers\LVClassLibrary\CLSUIP_MemberTemplate.vit.  I highly recommend making a backup before doing so.
Darren
Proven Zealot
Status changed to: Declined
