13 | |
11 | |
3 | |
3 | |
3 |
If you've got a project open, any new VIs you create automatically get added to the project. It'd be nice if there was a way to disable this feature.
I find the feature frustrating because:
- I often create new VIs that I never intend to save, just to test out some logic quickly. However, I can't just close the VI -- I need to go and remove it from the project too -- and this also leads to a dirty dot in my project (and extra work).
- I'd prefer to have full control over which VIs get added to my projects, and where they added within a project.
- If you've got more than one project open, you have to be careful about where you press "ctrl+n" from.
- I've found myself in situations where I close a project after creating a new VI, tell LabVIEW that I don't want to save changes to the project, and by doing so inadvertently lose the code in the new VI because I'd overlooked that automatic association.
