I would like an option to hide cosmetic differences in the LabVIEW Compare VIs tool.
I like using the Compare VIs tool to show differences between VIs (especially when used with LVCompare.exe with my source code control client). However, I find that cosmetic changes (like moved, resized, front/back order change, and visible frame change) are the majority (~90% in some cases), and having them in the list makes it extremely difficult for me to actually compare the functional changes to the code.
Thanks, in advance, for your kudos 🙂
