By default when a control/indicator is dropped in the FP/BD the Label is on top of the control and the developer needs to realign them for better UI.There must be an option in the FP and the BD with which the Labels can be aligned left, right, or on top based on selection.
See the attached image which better describes the solution
The same utilty can also be used to save some space in the BD as shown
