6 | |
2 | |
2 | |
1 | |
1 |
While it is easy to snap front panel elements to the alignment grid, no such helper exists if we resize, scroll, or pan the front panel.
In the majority of cases, my front panel has a size that is aligned with the grid, but it is often tricky to resize the window so this is actually the case. I propose an option that would snap the front panel size to integer multiples of the grid spacing when it is resized. Similarly, scrolling the front panel with the scrollbars would move the panel in units of the grid. Same for panning.
(Of course this idea here would no longer be really needed if this idea were implemented :D)
