13 | |
7 | |
3 | |
3 | |
3 |
Many common functions include a "found" or "exists" output. Examples include:
Why then does Look In Map provide an inverted ("not found") output? Wouldn't it be better if it was consistent with other similar functions??
This is most frustrating when replacing existing code using variant attribute lookups with equivalent maps. "Look In Map" is pin compatible with "Get Variant Attribute" except for that one inverted output! This has caught me out on more than one occasion...
