6 | |
5 | |
3 | |
2 | |
2 |
If there is a option for overlap in the structures (while loop, for loop, case structure) it will be is easy for wiring with deleting the structures as shown below.
In the following picture error cluster overlapped so that it came inside the structure without disturbing the wiring
Duplicate of http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-structure-resize-to-capture-code-not-just-move-i...
