I don't know how many times I've built an application or packed library during my 25+ years using LabVIEW. What still annoys me extremely much is when the AppBuilder gets a tiny error, like "wasn't able to copy this file" (always at the END of the job), or something else having no effect on the (already built and completed) application or PPL itself. Still AppBuilder deletes the whole build, sometimes 30+ minutes time wasted, and simply tells you the build "FAILED".
My suggestion is: Make AppBuilder just a tad smarter and don't delete the EXE or PPL! Just let the developer know what file(s) to copy manually, or what post action didn't work!
