| User | Kudos |
| 11 | |
| 10 | |
| 7 | |
| 5 | |
| 4 |
We have all seen it. Most of us have done it. a vi is saved with the BD or FP positioned on the secondary monitor and deployed to a single monitor system. Opening the vi saved this way IS cought and the vi opens with a portion of the panel visible on the monitor. We DO have the Windows run-time position properties (And that saves a lot of trouble in the field for deployed GUIs) but we still have the development enviornment to consider. A Config option to "Allways save LabVIEW Panels on primary monitor" would be a real hassle saver.
